Power Steering
CanaryGT
AZ
The other day I had to replace the starter in the SHO. Before I did everything was fine. Now that I replaced it and started driving I now have a severe PS leak. I know we moved the cooler out of the way in order to get the starter installed easier. So after I put more PS fluid in the rez, I noticed that it is coming down the line and dripping off the fins of the cooler. If you are looking at the car, from the front, its the left hose. Any ideas? Is that A H/P or a L/P hose? what does it lead to ? Thanks!!!
kevinspann
Don't take my advice.
Richmond VA
Low pressure hose. Goes from the rack to the cooler, back to the reservoir.
Should be 3/8" bulk hose, to replace it. Though I think the line out of the rack as a fitting on it, I would imagine you can splice a new line in if need be.
