89SHOMAN666
SHO NUT!
Hello All,
I'm having a problem with my power steering in my 89 SHO. Whenever I have the RPM low it screeches terribly it also does it whenever I corner at a high rate of speed. It is a very high pitched screech. It's especially bad when you're for example parking the car and you're going slowly in reverse. Finally it also gets worse as the weather gets colder.
Any suggestions? Do I need a new power steering pump? I've heard the OEM Ford pumps kind of sucked to begin with so I dunno if that's part of the problem or not. headbang
Thanks in advance for your help!
Later,
Later,
