Power steering fluid?
Slo-Sho
It wasn't me!
Crossroads, CNY
I was told by a mechanic that it was OK to use ATF in the power steering. Is this true? If so, what type would be acceptable for use...Type F, Dex III, etc?
38SHO
#1 Oil Abuser
North Palm Beach
any
mercon V wouldn't be bad because it can take some more heat........
but its more
or any synthetic ATF.... but its also more....
I run just regular ATF mercon/Dexron 3...........
itwonder
VA
I choose to flush with cheap Walmart Dexron ATF, then fill with Valvoline Synpower PS fluid. But I think you will be fine with any quality name brand Dex/Merc 3 ATF like Todd says.
Devin
3.Slow
Pacific Northwest
AMSOil ATF. Took a little bit over a quart, dry, if I remember correctly in my 90.
