power steering fluid or atf???
sho_bc
Dragonboater
Vancouver, Canada
just got back from an oil change... and was told that i shouldn't be using power steering fluid, but automatic transmission fluid. some sort of Ford thing.... true? what do you guys use? (they also printed out some stats thing that said the same thing..... SHO specific)
sho_bc
Dragonboater
Vancouver, Canada
lol. sorry. that was for the power steering. and i've talked with my dad about it, and he's got a Ford specific power steering fluid in there.
drdave
You could flush your power steering with ATF if you want, but I would use synthetic power steering fluid in there. But I would just as soon flush it with cheap PS fluid.
GreenBird
Barre, Vermont
Power steering fluid and ATF are the same thing. Marking it power steering fluid just allows them to mark up the price. squint
LaTechSHO
Louisiana
GreenBird:
do you have fluid stats to back that statement up?
Louis
shojuan
sunny San Juan Bautista,
Use the Paul Nimz method of power steering fluid change. The first step is to slowly replace old fluid with new to help clean off the soft to medium deposits. Crap that would just dirty up a complete fluid change right away. It goes something like this:
Get cheap type F (or whatever your manual specs. My '89 specs Type F) ATF. I used Walmart supertech at $1.27 a qt or so.
Suck out the resevoir, my 89 holds about 12 oz. I use an old turkey baster. Then fill up to the full cold mark with the fresh, clean, and cheap Type F. Repeat every other day for a week. Then start doing the same thing every 4 days or so. Then after a week or two of that switch to doing it once a week. After about 3 or 4 quarts of cheap stuff I bought a couple quarts of high quality conventional Type F: Castrol. About $2.69 a quart at autozone. So, I'm going to swap that in a la turkey baster whenever I think about it as long as some mileage has accumulated. I would probably be fine if I just left the castrol in there. The fluid has stayed clean even before I started with the Castrol. But what I'm going to do is:
When I get the last 12 oz out of the second bottle of castrol then I'm going to add an oz of auto-rx to the power steering system and drive that for 1000 miles. Then I may or may not turkey baste fluid out for a week or so depending on if it looks clean or dirty. Then I'll drain the system completely and replace with Redline power steering fluid. I called Redline up and they said it would be just fine in a system that requires Type F. Then I'll add another 1 oz of auto-rx in the system and forget about it. I might put a filter on there, I don't know. They're cheap, but I'm lazy.
You know, when I mentioned the Paul Nimz method to Frank he said he was glad I brought it up. Frank had just spent a good chunk of change getting his powersteering system purged with a fancy machine. I forget how much time had passed, it wasn't much, and Frank said that his power steering fluid looked black again. This is what the Paul Nimz method aims to avoid. Frank's going to give that method a try next time.
bmytych
