Electricat
I have a popping and clunking when my front suspension loads/unloads that I have been unable to diagnose.....within the past 2 years, I have replaced the entire front suspension plus wheel bearings, except for the strut mounts and bearings. The strut rod cups in the subframe are not loose, and subframe bolts have been retorqued.
(I have Moog control arms, Moog springs, Moog tie rods, Monroe struts, adjustable strut rods, TRW sway bar links, ALSFB's, and all bushings are TPR or poly).
Since the mounts and bearings are the only original parts, they are the obvious suspect, but I don't have the money or time to just replace them on a guess. So my question is....what would be the symptoms of either or both of these parts going bad?? Any other thoughts?? Is a certain amount of clunkiness just a part of having the stiff springs and TPR??
