Pinstripe removal
megaplay
Cincinnati OH
Anyone have suggestions to best remove the pinstripe on the side. Looking for a little cleaner body line. Thanks.
How about stuff like goo gone or whatever the adhesive remover is called in the local autoparts store.
SHOemup
Dalton, PA
to remove the stripe itself I suggest taking a heat gun or hair dryer to it and slowly roving the strip as it gets hot. Be sure not to let the heat stay on one spot, it could damage the paint. After the stripe is removed, you can use products already mentioned to rid the excess adhesive. Good luck
