pads for the 96 brake upgrade
viperrt450
Downers Grove, IL
first which style of pads will fit the 96 brake upgrade? And second which ones r the best for hard driving. I have a set from a 96 SHO and they don't fit.
Xs SHO 1
Unknown
McHenry, Illinois
it depends on the on the setup u have. by the way, did u find ur caliper bracket? if u have the '95 Continental bracket, the '95 Continental pads will fit. again, i believe that the '95 Continental and '96 SHO have interchangeable parts, same part just different part NUMBER......
viperrt450
Downers Grove, IL
the only email i got from u terry was that u said u have ceramic pads and thats it. You said u were going to write me another email with the pad #
AutoXSHO
Glenwood, MD USA
I run the "Ceramix" pads that Doug Lewis sent me when I ordered my '96 brake upgrade. I like them a lot. They are comparable to the Carbotech Type F pads I have in the rear. These pads (the Type Fs) are discontinued.
The '96 SHO pad will fit. I know, because that's the size I run up front. If they don't fit, something is wrong wink
John V
fordfanatic4ever
middletown, ri
I don't know why you say the 96 SHO pads won't fit. i have them , direct from my friendly Ford dealer on my 95 SHO and they work great, of course they cost more than pads at autozone, but they are good pads. I have had them on my car for a year and not appreciable sign of wear.
viperrt450
Downers Grove, IL
i tried putting the 96 pads on but they will not fit under the brackets on to the caliper. The pads that i got are the carbotech panther pads. I'm going to try agian to put them on.
<small>[ May 24, 2002, 06:35 PM: Message edited by: viperrt450 ]</small>
viperrt450:
Here is the Ford pad for the Gen 3 SHO. XF3Z-2001-CB $ 57.99 from www.fordpartsnetwork.com
Do not get the Motorcraft as they are not as good.
