oil smoke...
BeatDaSHO
Hatboro, Pennsylvania
aight. i think that my front main seal is leaking oil onto my cat. This produces some smoke occasionally. Do you think this is a huge problem if i leave it?? Will it cause a fire or anything? later
Greg
No fires. Just smoke. How long till the next timing belt?
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
89SHONOFF
Columbus,Ohio
you sure its oil,On mine its leaking PS fluid onto the cats because from steering it the line jas pubbed aginst somthign causing it to have a hole,it smokes really bad too and has gotten progressivley worse thats why its in the garage now,id check that out and when it gets on the gat it leaks like crazy
1989 SHO Lt.Titanium
K&N Filter
Msw Wheels
Hopefully More Soon!
1968 Buick Skylark W/455 Stage 1
70 Ford Torinow/302 and 60k miles.
BeatDaSHO
well i'm not quite sure if it's oil or not. It's definately oil or power steering fluid but i can't tell which one. how can i tell which one it is? and if it's the power steering fluid how can i fix this?? get back to me man. thanks. peace
Greg
