hello.Constant reading about motor noise has me confused.I have a 95 3.2 110,000 miles.I have this problem of no matter what speed i have the accelerator pedal at when i push itvery slightly,there is a very low more like knocking instead of ticking coming from the top of the motor(sounds like)the more I push the pedal the sound will go away.it will do it at low or high rpms.when i'm cruising,there is no sound.the oil light does not come .It idles very smoothe(no noise)and drives on the highway,or in the city fine.The sho does not overheat.it makes the noise at hot or cold engine temp.(only when I press the pedal) I don't know if the rod bearings have been done or not.If I put in a oil pessure gauge,is this a good determining factor for bearings(if low pressure)I really do not want to tackle the bearing job mysef.Trying to find a sho mechanic in las vegas is a tough job.Any help or suggestions would be greatly appreciated.Thanks a bunch. stumped. p.s the oil pressure switch cannot be seen from under the car.From top it looks like atotal pain to get to.
