sho_shane
I have a noise coming from under the hood. I say under the hood cus I dont know for sure where its coming from. Motor or Trans is what im trying to find out.
I have a 1991 SHO with 183K on it. It had the Rod Bearings done at 171K and the last 60K was done at 94K so I know its time for that.
I have a tap/knock that only happens between 2000 and 3500RPM, It only does it when the car is moving. If you rev the motor sitting still in gear with the clutch in or out of gear with the clutch out its smooth as glass and not a wierd sound at all. But if your raising in speed you can hear it from 2000-3500RPM. Sometimes you will not hear it at all and sometimes you will. To me it sounds like its coming from the drivers side of the car but I know sound can traval in metal so im not sure.
I would really like to know what yall think and any help would really be great.
