SHOfun 93
Okay,
After taking my wheels/tires to be mounted at Discount, I picked them up and installed them late last night. No problems it seemed, until this morning.
I did notice last night that the factory lugnuts were so wide that I couldn't get a socket or a lug wrench around them to really get a good tightening, but tightened them down to where I THOUGHT they were good and tight.
My wife and I took off to the gym this morning and there was HORRIBLE grinding sounds coming from most of the wheels. So we babied it home and I proceeded to check for brake clearance, etc etc... When I would apply the brakes, the problem seemed to go away, therefore my first assumption was a loose caliper bolt causing contact of the caliper with the rim...but there was PLENTY of clearance between the caliper and wheel....
No problems when I jacked the car up and spun the wheel....hmmm..odd...then I gave the wheel a little wiggle....seemed tight enough...well I then investigated the lugnuts. I COULD SPIN 2 OF THEM OFF WITH MY FINGERS!!!!!!!!!!!!!
When I dropped the car down onto the wheel, even MORE lugs were able to be loosened with a slight turn of the wrench or my FINGERS!
I dunno if the loose lugnuts were causing the vibration of the wheel across the threads of the lugs, because there is NO problems with clearance on any of the wheels as far as brake calipers, hubs, or spring perch..
Has anyone heard of aftermarket wheels needing different lugnuts? It seems the factory "lip" that is on our factory lugs is preventing me from tightening the lugs correctly, that and I can't even get a lug wrench/socket around them.....I guess I will go look at discount for some aftermarket lugs.....any suggestions?
BTW, the tires are only 225/45/17, and they are the 40mm offset (which should be okay, correct?)
That's what I get for assuming that something would go smooth when it deals with a SHO!
