New Tires
stephen newberg
Ladysmith, BC, Canada
Well, I got a nail in one of my old tires the other day and on looking at it decided there was not really enough tread left to be worth fixing it. Not to the wear marks yet, but pretty close, and I had been planning to get re-shod soon anyway. So to the tire shop and after a bunch of looking at this and that I decided to try something new, having run the Bridgestone 900 series since back when they first made the 910.
Ended up with Yokohama Advan S.4s. Anyone tried these yet?
pax, smn
Kate Caretto
SHOLOVE
Michigan
I just checked those at tirerack.com. Definitely let us know how you like them. I'll be in the market to replace my Yoko Avid V4Ss real soon.
Brent
Port Alberni, Canada
I have never tried them, but I have looked at them, and I do like the look of them. But I am on the second set of my AVS sports and love them. Far as I know they will be my last ones.
stephen newberg
OK, I can now comment on dry pavement handling. Yesterday I had to take a run down to Victoria and back. Between my home on the east central coast of Vancouver Island and the southern end where Victoria is located there is a serious mountain that you have to go over called The Malahat. The road over the top is heavily curved with major ups and downs tossed in, plus a few poorly cambered sections and one curve they even managed to reverse camber to a couple of hundred meter dropoff. :)
On my morning trip down I had to keep the speeds in reason due to traffic and law enforcement, so I averaged about 60mph, which is well over, but within the range that you can run without huge amounts of weaving in and out of traffic and attracting a lot of attention. The limit is in the 40-50 range, depending on location. Tires were fine, but that is not a serious test, and anyway the opposite direction is the one with the better test sections due to which areas are double laned and which single.
So on the way back in the evening, with the traffic almost gone and the police well tucked away in their beds, I ran it up and average about 80mph for the uphill really fun section, including those areas with the bad cambers. Overall, I am most pleased. Steering remained between neutral and mild over, which is where it has been set by the other suspension mods. Tracking was excellent, and even when pushed by the reverse camber there was no squirm or roll under from the sidewalls. But the temp was 16C (about 60F or so), the pavement dry, and conditions pretty optimal in that the road is well maintained and very smooth.
So, for this aspect, the Advan S.4 strikes me as at least as good as the Potenza 960 in mild, dry, smooth road handling, and may yet prove better after I get a chance to push hard in some location where if things go wrong you do not end up flying down a couple of hundred meters to the next flat spot (which then turns out, in this case, to be the Pacific Ocean). Oh, and they are quieter than the 960s both in just normal use and when pushed hard, which is nice. :)
First time we get some decent rain (which considering summers here might not be until October), I will take her out and try out the wet weather adhesion on back roads. Cold weather testing will have to wait until December or later, as it pretty much never gets below freezing here prior to that.
pax, smn
Kate Caretto
SHOLOVE
Michigan
I like the Avid V4S. I really haven't had any tires to compare them to on the SHO except Blizzak snow tires, but I don't have any complaints. They've lasted me over 35 thousand miles.They are quiet and pretty good in the water and snow (when they were not so worn).
stephen newberg
Very pretty, but it has nothing to do with the post, which was asking about the Yokohama Advan S.4. :cool:
I had a bad time with a set of Kumho Ecasta 712s a number of years ago, and would no longer buy from Kumho, though a number of people have indicated to me that they have improved them since then.
pax, smn
stephen newberg
Surprise of surprises for Southeastern Vancouver Island in the summer, but we just had 6 days of rain, once or twice actually heavy. As a result I have had a chance to try the Yoko Advan S.4s in the wet a lot sooner than expected, and they were just fine. Including on the first day when a lot of oil would be getting lifted from road surfaces that had been dry for a couple of months of heavy driving. So, wet and dry on new tread in warm weather, a very good tire and worth the money. Still in question to be determined later are the same questions in cold weather and then again for both as the tread wears down.
pax, smn
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
I highly recommend Toyo Proxes 4 tires. I had two sets of them on my 99 and they NEVER let me down. Maybe give them a try after you wear down those Yokos.
stephen newberg
The interesting thing about tires is they are in constant flux. With ongoing research and testing, plus such a huge 'road test' population (everyone that drives :) ), new things are always being tried out by the major manufacturers, and hence a couple of years down the road when you need new tires, there is almost always an interesting new pile of models to choose from, should you be interersted in switching (and often you have to as the old model simply is no longer made).
pax, smn
