Titanium89sho
I have been reading up on suspension and just purchased an Intrax/Koni set-up for my SHO. Is there anything else I should replace at the same time besides upper mounts on front and rear? Any help is appreciated.
DemonNeno said:Yes, the bearings, strut mounts, which are known to wear out, try the former Midwest SHO strut mounts, they're reinforced. Sway bar endlinks would be a good idea, especially up front. Try to replace your balljoint grease boots if possible, there's a good chance you may puncture them upon removal.If you have any cracked/damaged halfshaft boots, this would be the time to replace those as well. Finally, i highly recommend TPR/Polyurthene bushings. These are all things that you will have to disassemble to get the struts out. Some may require only disattachment from the strut/spindle, but if it's half way off, why not replace it if it looks shot?
Rockledge said:When I put new Eibachs/Tokicos all around on my SHO last winter, I also did the following: installed new strut mounts and bearings, new front control arms (ball joints are integral), new TPR tension strut rod bushings/washers all around, new aluminum Windstar endlinks up front and new Napa units in back.
You should go with new hardware, you're gonna need new pinch bolts at a minimum.
I got almost everything I needed from SHONUT:
* Front Strut Bearing (2) #F4DZ-3B455-A
* Front Upper Strut Mount AD-930-A (2) #F1DZ-18183-AA
* Police Rear Upper Strut Mount (2) #F3DZ-18192-B
* Front knuckle/strut pinch bolts (2) #N803-989-S426
* Front Strut Washer set (2 of each) #N804-002-S100-W706-671-S430
* Rear Strut Washers (4) #N804-232-S100
* Rear knuckle/strut pinch bolts (2) #N801-942-S100
* Front Swaybar End Links (2) (Windstar) #4R3Z-5K483-AA
* SHO NUT Reinforced Front MTX Mount #SNP-RFMM
* SHO NUT Reinforced Rear MTX Mount #SNP-RRMM
I picked up the TPR strud rod bushings/washer set from RCM Automotive (#RCM-912)
I highly recommend the SHONUT reinfored motor mounts if you are serious about upgrading the suspension and handling. Also, how are your subframe bushings and mounting hardware? Has your SHO had safety recall 98S36 performed on it? This is another area that shouldn't be ignored.
Finally, you're probably going to need new bumpers and bellows for the new struts.
