New owner of 2015 SHO
Brated
US
Hi everyone just got this 2015 SHO very nice ride 1st time turbo owner always drove NA cars. About a week ago I turned the car on and let it warm up like I always do jumped in to go to work and I felt like I was diving a turtle. Like I said 1st turbo so I'm kinda lost any help would be greatly appreciated thanks
grayj1979
KCMO
First thing to check is boost line just under the engine cover. Enough oil / grease will build up around the connection that under pressure the hose will blow off. A zip tie will usually solve it if this is the deal. At the same time im not even remotely qualified to answer this question, just saw you hadnt gotten an answer lol.
17f9c0386deb3f14bf5e37383676908f
Florida
What are the symptoms? the boost lines are always a good quick thing to check and usually an easy fix (so Ive heard) but if its revving freely and not moving could be transmission related, if its falling on its face when you try to accelerate it could be a number of things but less likely to be a boost issue. if its driving fine just feels sluggish like a worn out NA car then could be a boost clamp came loose or a restriction somewhere. if you can put up a more detailed description of what its doing we can maybe help you narrow it down. first things to check would be your boost lines, turbo clamps, noisemaker, and air filter.
Brumfield780
