new guy
gmac
just got a 95 sho atx has about 62000 miles and completely rust free. Bought it for my son to take to school my question is the easiest way to change the cam position sensor maybe step by step would be greatly appreciated
thanks
For some reason pics are missing from the SHOPhoenix website
C.I.D. Removal - MTX/ATX cars
Thanks to Josh (SASHO91) for submitting this article
I Have noticed that many members have had some issues when trying to replace the CID (Cam Sensor), which is located on the rear (right) bank, on the exhaust cam. This is due to the fact that space is limited in that area, and most of us don't have hands of a 5year old. These pictures were taken on my 93'.
Here is the tool list:
1/4'' Drive Ratchet
1/4'' Extensions (at a minimum, 2-3 4'' units; the pics will explain)
1/4'' 5/32'' socket
1/4'' swivel
NOTE: If your car has been lowered, you may need to raise the passenger side slightly to gain access to the fender well.
Grab your tools (and connect them properly), and follow the pics.
--Here we are looking through the passenger wheel well. Notice the strut/spring. As you can see through the small hole, you have access to the rear, P.I.T.A, CID bolt.
Upload 2016 9 1 18 53 14
--Here we can see our tools connected together, and inserted into the small hole in picture 1. Notice that going through the strut/spring is a direct shot. If you do not have access to long extensions, you may be able to use just one short extension and use the ratchet close to the unibody.
Upload 2016 9 1 18 54 5
--Finally, a picture from inside the engine bay. Self-explanatory there...
Upload 2016 9 1 18 54 32
As for the 'front' bolt, you can use the swivel and get to that one as well.
For ATX cars; This method is not needed as much as on the MTX. Reason being, the ATX engine sits farther forward, which in turn makes for a slightly easier access to the CID. I HAVE used this method on ATX cars, mainly because of the ease of the removal/install. If you do use this method on an ATX car, you WILL need a swivel regardless, and the front bolt will be slightly harder to get to (due to the location of the engine).
For those of you who might not have figured it out, reassembly is reverse order of disassembly.
gmac
thanks will give it a try tomorrow car runs great just has a hard time starting sometimes almost but doesn't.Thought this is a good place to start
black92
Wisconsin
I agree, this would be a good item to replace. Would not hurt to check for codes, regardless if the check engine light is on or not.
AREA 91
PA SHO SHOP
Area 91
Chances are that the camshaft seal is leaking. If you see any oil when changing the cam sensor, it should be replaced.
