MGidish
I have done the 3.2 swap. It runs fine and everything but..i am getting some codes. the one that is left is " 511 PCMROM FAILURE ". I have the stage 4 kit on and have for a couple of years now. my question is, would this code be due to the LPM? Also, would i need to send you my LPM to get reprogrammed for the 3.2 swap? I also got a code " 214 CYLINDER ID [CID] CKT FAULT". this went away and am now left with the code above (511).do i still need to figure out the 214 code as well?
on another note, i have the 68mm throttle body that is sticking pretty bad. it wont release all the way. could i get a replacement or any advice to fix the sticking? Thanks!
Michael Gidish
<small>[ May 04, 2003, 02:19 AM: Message edited by: MGidish ]</small>
Michael Gidish
