Mr Josh Zombie
SHO newb
I just bought a new SHO last week, and on the way home from signing the title over, the CEL came on. The car didn't act any differently what-so-ever, so I figured I'd look into it later. Well, 3 days go by and I finally get around to it.
I cannot isolate when the CEL pops up... it seems to be quite random. Also, my spark plug tubes are filled with oil. I know I need new valve seals, but wasn't sure if that problem would cause any of these to pop up.
539 (O) System shows voltage at PCM pin 10. Is A/C on ?
Codes that were stored on the PCM.
176 (M) Oxygen sensor not switching - system is or was lean Left or Front HO22SSS - Fuel control
332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
543 (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits (M) (Service 556 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
I did a little googling and couldn't find any info for fixes to these problems. Any help?
