MTX resonator internals buzzing...
nkb93
SLO 4 SHO
Charlottesville, VA
I have a dynomax resonator pipe on my ATX to MTX conversion (rod shifter). For awhile the resonator has been making a really horrible buzzing sound that's very prevalent at 2k rpm (metal to metal noise, not exhaust noice), so I assume something has broken loose inside of it.
I was considering getting a glass pack and welding it in place of the resonator. Any ideas what would work? I came across these:
http://www.magnaflow.com/02product/displayapplications.asp?partnumber=18135
I really just need to get up under there with a tape measure and caliper and check the dimensions.. I guess the question is, what would you get? I have stock rear mufflers and a magnaflow catted y-pipe. Do those glass packs hold up pretty well?
Thanks,
Nate
moobypets
mooby
quebec
get the magnapack from sho source or get a bigger version off the same part way better then glass pack and will remove any high note in your exaust
