mount trouble
raphy rod
las vegas
hello.I have a 99 sho.I was having noise problems from underneath while braking or turning sometimes.I get underneath and check it out.my right rear(by passenger) mount is broke in half.I decided to tackle the job myself.I read all kinds of postings and instructions to help.I decided to do all three mounts while under the car.I cannot understand how to get the old mounts out. There is absolutely no room for the rear mount to pull it out.I lowered the subframe also.(i think) I loosened the 4 bolts on the corners of the subframe to where they are loose quite a bit.It looks like the subframe won'go down.And also the 2 big nuts in the middle of the subframeThe trans mount is also giving me a hard time.Can someone who did this procedure fill me in.is there other bolts on the subframe?do we have to take off the whole subframe?please help with this nightmare.thanks
raphy rod
las vegas
stuck mounts
by the way,this is a atx tranny.Right now the rear mount is unbolted and i tried to take out again.there is no room.Do I have to take exhaust,or anything else off?Please help.I don't want to have to put together everything and take to a mechanics shop.I'm trying to do things myself.I lifted the engine up as much as it will go with a jack and wood block.Is there other parts holding the subframe up?I know it sounds like a repeat,but I'm stuck. Thanks again for interest.
