MOTORCRAFT AGSP32FSMF4 these the ones?
Twisted99
South East
MOTORCRAFT AGSP32FSMF4 these the ones? 95 3.0 MTX
these are fine wire platinum..anyone use these or what should I go with in a double platinum? thanks
projectSHO89
SHOless In St L
The fine wire plugs make the double platinums obsolete. You can certainly still use the double plats, but the fine wires work as well, if not better.
Always refer to www.motorcraft.com for the most current factory recommendation instead of using the parts lookup from auto parts stores.
Steve
bmytych
