tardboy21
Well, my old plastic links were startin to rattle around a bit, so I broke down and got some solid moogs. All is quiet now, however, I had one questions for anyone else who has installed them.
On the link, there is grease fitting on each end. One is on the back faceplate, and the other is on the side as opposed to the back. On the instructions, it says to install the end with the grease fitting on the faceplate to the sway bar end. In doing this, however, the other grease fitting is unreachable, as it points straight towards the strut.
I inspected them and both ends seemed to be the same. Installed it the opposite way since the angles are the same upside down, and both grease fittings are accessible.
Anyone else do this before?
