I bought a new timing belt cover from members on this forum. I thought at first maybe it was from a 3.0 so I reassembled my broken one and sure enough its the same exact one.
I broke my covers to get them off. Getting them back on is now the major issue. The lower cover lines up perfectly. The top cover as well. When I put the middle cover on, the right side will go flush, but the left side keeps bulging out and wont line up properly.
This is the gap between the top portion of the lower case, and the bottom portion of the middle case.
This is where the lower case bolts into the middle case, on the far left of both cases. I cannot get these two to line up properly.
As you can see, the right side of the middle case sits flush, where as the left side of the middle case does not. The lower case is properly alligned and bolted in. Any help on this would be greatly appreciated. As always, thanks in advance.
