sperold
Last to Know
I took the MAF sensor off the flex tube assembly to clean it (with a sensor safe cleaner from CSC). It had 4 torx-like fasteners with pins in the center that needed special sockets to get them off.
The surface to surface plate connection has a lot of dusty looking stuff (like aluminum oxidation) and I am wondering what to do with this. Should I clean it off, or should I apply some dielectric grease to make a great connection, or what ever?
This thing seems to play a big role in the induction system so I want it to be correct.
Also, this little sensor sit in a small hole above the full size tube. Should I get lots of cleaner in this little hole and see where it comes out. And, while I have the cleaner out, how does that mesh screen prefer to be cleaned.... do I use the same cleaner?
I have a chronic lean mixture situation, and I am hoping a good cleaning of this part will help.
