It's a tight fit, but you can easily do it if you remove the front passenger's side wheel and the fender liner if needed. Just drain the radiator first.
If the hose is baked on real tight then try to work some silicone spray underneath: Carefully pry the edge of the hose up and spray silicone under there. After working a little bit in there it will make removal a bit easier.
