low sho...
sho2crp
MA
i wanna lower my new sho its a gen1, 89 i wanna get coil over but can't seem to find any. if not what spring are stiff and lower the car for a nice stance....
thank you
DHMag
Free At Last
InCahoots, Texas
Koni does make a coiloversetup for the Taurus, though you will need your OE strut housings and a bit of fabrication skill. you can find them on Ebay for roughly $420.
another option is buying Moog springs and cutting coild from them. i have cut Moogs on Tokico struts. cutting 1 1/2 coils on the front gave me a 2" lowered stance.
PROPHET
Well-Known Member
Tonytown, Texas.
Go with Intrax and Tokico or Koni strut combo.
The coil-overs are more of a track set-up.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
You can get Coilovers through Midwest or GroundControl (same thing). You would have to get Konis to go with them though.
Ihave Intrax and it lowers it and it handles very well.
jedhead
westminster,ca
You can also search for some used SS linear Springs.
Intrax/Tokico
SS Linear/Koni
Bob
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
Same here.. If my car was white we would have alot in common :thumb:
TURBO91SHO
Boost Hungry
I have Ground Control/Koni adjustable combo. I called Ground Control and asked if they had a coilover kit for the SHO and they told me yes, but I had to use Koni's.
coldsho
Chalkboard SHO
algonquin il
i was told on both sites that u could get ground controls to run with other aftermarket struts such as the tokicos
DVJ38
Hartford, CT and Worc, MA
How do you like the ride with 18's? I'm thinking 18 inches too, but not sure if I want coilovers.
AREA 91
PA SHO SHOP
Area 91
I have the Mid West SHO Coil Over's with adjustable Koni inserts. Very harsh ride, compared to my kyb equiped SHO.
