low end stumbleing
Dr_Thompson
CT
hey everyone. Got a problem. I replaced the the fuel filter, and i had to take off the intake to replace a broken water housing stud. Put it all back together and now it fumbles and stumbles in the low end, pretty much below 3000rpm.Checked fuel filter, flow is towards the motor. I figured maybe the secondaries are stuck open, nope. Everything looks fine as far as vac lines go. Im pretty sure i screwed something up putting the intake on, i just cant figure out what. Any specifics on what would cause the low end to putter. The car is driveable to, just puts a bit. Thanks!
89shofun
Guest
franklin wi
yo i took my intake off to paint mine does that now also i have no clue why . i did remove my intake horns still have stock setup im lost lol
ViPER1313
Ijamsville, MD
Did you loosen all the clamps on the snakes before you bolted it down? Did you use new or old gaskets when replacing the intake? Did you install the fuel filter so the flow is in the correct direction? Also, check the ground wire for the DIS.
89shofun
Guest
franklin wi
hey i used new gaskets and had to make new boots for the snakes my ground wire is on a bolt on the top of intake it didnt work when trying to put it back in oem spot
