line to caliper fittings
qshipsho
NJ
Does the 89 SHO stock front caliper has the same type of brake line fitting as the PBR twin piston upgrade caliper (where the brake line attaches to the caliper).
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
Yes and no.
The Earls and stock lines both bolt up to both PBRs, 89-93, and 94-95 calpiers just fine without modification.
The stock brake line blocks need to be slightly modified to bolt up to a PBR caliper (file off one side of the block).
Hope that helps
- Mike
