ohfosho
ontario SHOwner
ok guys i got my codes... i was hoping it would be a sensor, but then again i hear the VSS is a b to change...
so i'll just post all the codes:
172 rear/rh hego sensor indicates lean
176 front/lh hego sensor indicates lean
336 exhaust back pressure high/PFE (*?) circuit voltage high
452 issuficient input from VSS / malfunctioning
543 fuel pump secondard circuit failure (*?)
411 idle too high (i had the car at the normal temp lower line at the first test. i checked again and that code did not pop up)
632 tranny control switch not cycled (i belive my OD button is not hooked up presently...but OD is on) this code is for the Over Drive switch right (*?)
9 all cylinders ok for ballance test
so i have the new sensor, im looking for the easiest way for the driveway mechanic to change it out.
please add input for spots marked (*?)
