Key FOB
reags8
Connecticut
I picked up a 92 MTX and only got an ignition key and door key, now here is the question that someone on this board I know has the answers:
1 Did the 92's come with a FOB?
2 I see OEM Ford FOBs on ebay that you can purchase and program, will one of these work ?
Thanks
iirc, it was an option - if you have the keyless entry pad on the driver's door, then you have what you need for a fob to work, but if I recall right the ones without the keyless entry did not have the receiver module for the fob to work.
there were several different fob styles available over the years and they do not all interchange, so you need one for the proper year/model vehicle.
reags8
Connecticut
Thanks Ruby ..... I do have the keypad on the door and am hopeful I can find a FOB on ebay that will work.
zoomlater
Seattle, WA
I have had two 92's with keyless entry and none of them had a key fob. I have the 92 dealer brochure and it doesn't mention a key fob, only the keyless entry. Maybe someone else who has had a 92 can chime in if they had a key fob or maybe adapted one
TimboSHO
Intermediate
Wyoming, MI
I thought the factory FOBs started in 93, and if you want a factory FOB, you need the RKEM from a 93-95, along with the harness to splice in. I have everything including the wiring diagrams, but now don't think it's necessary for a race car i never lock anyways.....
that's possible, things from 20 years ago are a little foggy in my head...
