Just ran the Codes..
SHO Nick
******, Cali.
Off Position: 52, 84 Saved Memory - 33
Running or On Position: 41, 33, 52
(Once I got 73 Aswell.)
Keep In Mind my EGR is not hooked up right, the valvs is there, but the sensor near the air box is gone, and all vacumm lines are disc.
ALSO...I have an exhuast leak since the Y-pipe is not 100% on Correctly..and a very very very small Intake Leak Maybe..
Please Help...
-Nick
Rockledge
Pluggin' away
Connecticut
With your current setup, the codes seem to make sense me.
The 33 and 84 are EGR-related codes. You have to expect those since the EGR system has been disabled on your vehicle.
Code 41 is a system lean code. With EGR vacuum lines disconnected and an intake leak, you would have to expect a lean conditon, too.
If your power steering system seems OK, then the code 52 probably means you didn't turn the wheel properly during the code-pulling process. Otherwise, your SHO has a problem with the power steering pressure switch and/or circuit.
SHO Nick
******, Cali.
Yeah, I didn the steering, but it feels okay...so dunno, ill take a look at it later on...Thanks tho! :thumb:
