oneqwicksho
Hi Everyone
My 90 taurus sho has a bad outer tie rod end and was going to do new inner and outer's. With the inner's I've seen on here that there is a rivet that holds it on and with new ones there's set screws. The ones I've picked up don't have a set screw it comes with lock tight. My question is this: is the new one going to be a problem since its lock tight instead of set screws? And is it worth replacing them when theirs no sign of wear? Just figured while I'm there even thou the outer ones are the only thing that needs done
Thanks Mike
Thanks Mike
