Idler Pulley replacement
brobsho
portland
So what is the most cost effective route in replacing the idler pulley on my 94 3.2l sho. My lower left hand pulley is squeeking like a dieing pig since replacing the belt. The dealer wants $123 and nobody else carries them. I have read other posts and did not get a sense that there was an alternative for the lower pulley. Does anyone know if this is the case? Or can I pop the bearing and go to bearings inc for a replacement? Or should I search the local wrecking yard?
rendyx
Buffalo, NY
Look around, my friend, look around...
$27:
The real question still remains, does it fit? :D And, this is the front upper pulley, I'm not sure about the lower. Hopefully some inspiration though! Check www.rockauto.com
<small>[ April 11, 2003, 11:44 PM: Message edited by: rendyx ]</small>
