I need a trans mount f5dz6f063d
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
yep, look at rock auto i think they are the cheapest... forget that number, search for mount and you should find it I think.
I believe they can be found at Advance, and O'reily also..
93rev2sev
Hockeytown
Rock auto does not show the mount, actually. Yours can be temporarily (or permanantly) bolted back together, though, so don't let a separated trans mount keep you from putting your car back together.
I just did this to mine last night. It hadn't separated, but it was starting. I'll get a picture, but basically you just drill a hole, put a carriage bolt through from the bottom, stick a large poly bushing on the bolt and crank it down a little. Use a jam nut and you're back in business...until your new mount arrives...and I would recommend doing this to a new mount, also.
Edit: courtesy of the inital responder
P1040191
