I need a Rotund tool kit for valve Stem replacement
easy_stuff
Texas
Do you know where I can rent/buy/borrow a Rotunda tool kit to do a Valve Stem seal replacement on a 3.0 and a 3.2 SHO
msteiny
Grand Forks,North Dakota
What I have done in the past is retro fit a compression tester to my air compressor. Bring what ever cylinder you are working on up to compression, valves closed. I then fill the camber with air from the air compressor which holds the valves in place while I replace the seals. This method works on all types of engines, on most you need a spring compressor of course.
