Huge Bang in the back
SHOstopper
Burlington, MA, United States
ok the SHO went to the shop the other day thought i needed front stuts and new rear mounts. Boy i was wrong $1100 i guess i needed new tie rods ball bearing front struts and some other stuff but hears my problem they said the rear was fine but everytime i go over a bumb on the back passanger side i hear a huge bum and they said the mounts are good what the **** is it then and also when im one the high way and i'm doin about 70 my car likes to pull all over the road is it an alignment or did they mess up my front. Thanks Jason
RStalveyARFF
too many shos
Georgetown, MA
Jason,
First, is your steering wheel straight when you are going straight? Did the place installing all the parts align it after? Doing balljoints, tierods, and trust affect all alignment measures (camber, caster, toe) The pulling could be your tires, but could also be a clash of the toe, setting your tires on different courses. On the rear, is it every little bump in the road? If so, it is your strut mounts, if not, and it's only the big bumps, it could be your sway bar to body bushings, as well as shrunk strut rod bushings, or endlinks. Don't want to sound like an @$$ or anything, but next time man, take it to SMP, I charge a whole lot less, and the SHO is my baby.
greySHO
Baltimore, Md, USA
I have the same problem with my 92 and a bunch of people have leaned me towards thinking that the H-brace is bad (where the control arms connect to the frame) I would love to tell you what can be done to fix it, but still have no idea.
poffffd
