How to test the CPS before installing?
T
ThomasDooley
Guest
Does anybody know how to test a CPS before I install it? It looks like a magnetic switch with 4 wires going to it, with three of the wires shielded and one not. I'd sure like to know how it works not just why it works. I'm also thinking of tappong the waterpump weep hole a puttin a small tube to direct the eventual water around the CPS. Just wonderin and ramblin. Sorry.
Tom
Here is a link to a Wells Manufacturing site discussing the function and applications of Hall effect sensors.
http://www.wellsmfgcorp.com/counterpoints/Counterpoint3_1.pdf
The second column on page 2 describes the function of Ford crankshaft position sensors. There is also discussion of their testing. Read up.
Scott
1991, 255K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/poly, Alum front SFB, SS front/rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
T
ThomasDooley
Guest
Thanks Scott, that did the trick. That article would be good reading for anybody on this group. I'm going to get out my wiring schematics and push some voltage to the pick-up and see if it was the crud on the inside of the vanes that was causing the problem. Thanks again. If you're ever in Phoenix, look me up and I'll take you and yours to a nice steak dinner.
Tom
