How to remove hood struts?
shojuan
sunny San Juan Bautista,
I got the garage cleaned out and the SHO backed in so I can start my 60K. I want to remove the hood and I can't for the love of god figure out how to remove the hood struts from the hood. Go ahead and laugh now :) But seriously somebody please tell me how those puppies come off. Then you can laugh some more.
Rick
<small>[ August 23, 2002, 05:31 AM: Message edited by: shojuan ]</small>
93nighthawk
Mitchell, SD
look on the firewall where the struts connect. There is a metal piece with pin and c-clip. Use pliers to pull the c-clip, slide the bolt out, walla, strut no-longer connected. And remember, no Q is stupid, trust me I have asked a few "I should have known" ones. :D
Eric
shojuan
The spring clip on the firewall isn't what has me baffled, it's the top of the hood strut attachment to the actual hood that I can't figure out.
Rick
shojuan
OK. The hood struts make for handy prop rods, so I'm kind of glad I didn't figure out how to remove them from the hood *except* the driver's side strut dragged and caught on a whole bunch of stuff when taking the hood off and it didn't help that I forgot to disconnect the hood light wiring connector DOH! The hood is off, now the new shop lights are illuminating the engine.
I still am going to have to remove those hood struts from the hood because they are shot; and cool as my piece of pvc pipe that I use as a prop rod is, I'm afraid I must install new hood struts.
So my initial question still stands.
Rick
93nighthawk
Mitchell, SD
For the life of me, I can't remember if it unscrews out or you have to use a flat head screwdriver to push it apart on the hood. Personally I would go out and buy a new set and look at that end, it should give you an idea on how it goes on. Sorry could not be more help.
Eric
shocrates
will never know
NJ
My Helm manual states "Release lock clip by prying with screwdriver enough to remove lift" from the ball stud on the hood.
FordLover
Houston, Tx
On mine there is a metal piece that you must pry off first...then it becomes obvious, I just don't remember for sure.
-Martin
BeatDaSHO
Hatboro, Pennsylvania
on my hood, there is the ball and the strut fits right over that. To get the struts off, i used pliers and gripped the strut and turned it. This will pop the strut off.
Greg
Hubes
Burl., MA/Chesapeake, VA
when taking my old broken ones out i had a difficult time with the metal clip holding it in at the base. i dropped it somewhere. in the end i switched to just a nut and bolt combo. i feel it is easier than the metal clip.
PS if u look at my siggy, it was before i had new hood struts. there is actually some visegrips holding up my hood.
<small>[ August 31, 2002, 01:21 AM: Message edited by: Hubes ]</small>
