How do you reset the abs light on 2nd gen sho?
Brian Mullins
I’d like to reset my abs light on my 94 sho atx. Any help/info would be greatly appreciated. Thanks in advance!
anti lock or air bag light? First thing to try is unhook the battery cables for a few minutes and let all the electrical power drain out. Most lights should reset themselves after a few on/off ignition cycles
Brian Mullins
Thanks, I’ve done that in the past & it has worked. Just put 2 new abs speed sensors in the rear, disconnected the battery,, didn’t work. But the abs seems to be working properly. I can’t lock em up like I did before the abs sensors installation.
when there are no longer any codes, the light goes away on its own according to my experience. the fact that it is still on suggests there are still issues that need addressed.
TimboSHO
Intermediate
Wyoming, MI
Exactly. If there are no codes, there will be no light. Check and see what code you have first!
Brian Mullins
You can read the codes put out by your ABS system, and that will help your search for an answer.
How do I do this??.. I tried the paper clip method with the abs diagnostic port, but the abs light didn’t flash at all.. the engine light did though.... But I’m not good at counting the light flashes. I used an innovia obd1 scanner... zero engine codes on key on & engine running. But it doesn’t read abs codes
look in the suspension and brakes section, at the top there is a sticky "how to pull abs codes?" which will give you the detailed instructions.
