Go to
www.tirerack.com and see what they have available. They list 19 different 17" wheels for a 91 SHO.
www.discounttire.com lists 14 different 18" wheels and 32 different 17" wheels for a 91 SHO.
I've found that the Tire Rack is a little conservative on what they recommend as to tire/wheel combos. Which is good because you'll never have a problem with them.
Discount Tire recommends a 215/50/17 or 225/50/17 tire for a 17" wheel, and a 215/45/18 or 225/45/18 tire for an 18" wheel.
BTW, RI-SHO has 18s on his SHO with a very low drop and he doesn't have any problems rubbing.
Also, be careful in choosing tires. A very wide tire may grip the road slightly better, but can add quite a bit of unsprung weight to the car.
[edit]
Also, the offset of the wheel is more critical than the wheel size. I believe that the desired offset for a SHO is between 36 and 42mm. Someone please correct me if I'm wrong about these figures.
<small>[ October 13, 2002, 07:10 PM: Message edited by: wuzzzer ]</small>
