jdSHO94
Hello All,
I have been using the search function trying to dig up everything I could about others who have experienced similar issues, but so far none quite fit the bill. Its a 1994 MTX with 255K on the clock, and after completing the first round of work that I have done lately, I have a hesitation taking off from a stop- the engine hesitates and pops back through the intake, but only below 1500 RPM- past that it runs beautifully. The issue does not happen every time, if I am really gentle with the throtle and accelerate very slowly it does not happen. I have been doing A LOT of work prepping for a cross country move, so I will start with the list of what has been done:
valve cover gaskets and plug tube seals,cam sensor and crank sensor, spark plugs and wires (motorcraft plugs and denso wires), cam seals, crank seal, and of course the timing belt and tensioner. The O2 sensors were also replaced a couple of months prior to this.
After all this was done is when the issue started. Since then, I have tried diconnecting the MAF and running the car- same issue. Unplugging the TPS also has no effect. I subsequently replaced the fuel pump and it still occurrs, only below 1500 RPM. Removing the vacuum line from the FPR makes no change either, and I also went back in and replaced the intake manifold gaskets just in case one was damaged during the initial work. This issue is driving me crazy, and I really want to have this issue repaired before I leave in a few weeks. I would really appreciate any insight you all might have. :thankyou:
