Help me decide!! Soon!!
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Getting some wheels. Need your help. After seeing Jedhed's OZ's I just had to get new wheels. If someone with PS skills could put these on a blk GEN I for me I would be GREATLY indebted!
1: Centerline Viking -17x7 under 16lbs
2: Centerline Vantage - 18x7 16 lbs
3: Centerline RPM - 19x7.5 under 16 lbs
4: Kazera KZA - 18x7.5 20.7lbs
http://www.centerlinewheels.com/images/wheel_deals/viking_341_451x421.jpg
http://www.centerlinewheels.com/images/wheel_deals/431_VANTAGE SILVER_hi_451x421.jpg
http://www.centerlinewheels.com/images/wheel_deals/418_RPM BLACK PEARL_451x421.jpg
http://www.tirerack.com/images/wheels/kazera/swap/kazera_kz_a_bml_ci3_l.jpg
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
#3 definately.
Light, and the addditional width. They look decent too :)
As long as you can keep them straight. not going to have much sidewall!
SHOMurph
Ford B@stard
Arlington, TX
I like the Kazera's.
"could it get any blacker?!"
But I would only go with 17s. Anything bigger is just compensating! KIDDING!!
17s are good for all around driving with big ol' Cobra brakes!
rktmn
Well-Known Member
miami
I like the Kazeras too, but redsho was having problems fitting them in the rear of his car. The bearing cup interferes with the center of the wheel.
I would go with the 17's also.
Do they make those in 8" width?
Jose
92sho16
b00sted
Liverpool, NY
didnt you already have #3 and get rid of them because tires were to expensive? Well either way my vote is for #3 or #4.
sweet sho
Radium hot springs, B.C.
I have a set of 18's on mine with 255/35 and i still have space in betwen the tire and the wheel well. After i came home from the tire shop and really had a good look at them they looked so small. They were the same size as my 17's but that's because of the tire size that i got. Anyway to get to the point, when i looked at my car i would have rather gotten the 19"s but then were talking about the bling bling. :nut: You definately need the $$$$
check mine out http://photobucket.com/albums/v732/ettorino/
RStalveyARFF
too many shos
Georgetown, MA
I'd stay away from the RPM's Tim. Remember the problems Jason (KaoticSHO) was having with his car? They actually stress cracked!
Toolman
Boost it!
I have a set of 19in RPMS already, and have put quite a few miles on them. But they are silver, and I REALLY want the black. So, I am getting the black, and may get the 18's later as well.
BTW, the Kazera's only cost $185, the Centerline 18's are only $169!!, and the 17's are only $139!!!. That is a steal guys.
SHO92
Upper Freehold, NJ
If Centerline came up with a slightly higher weight rating, and something better then 7" width, I'd be all over them. The RPMs have been my favorite wheel that would fit a SHO since they came out.
I'll take a set of 17x 8(or 7.5) in white please.
Toolman
Boost it!
The white turbo has lived a long eventful life. So it is time to move on. Details to follow. Get ready INDY, the TOOLMAN IS COMING!!
If the Kazera's will fit I would go with those. I think the black would go well with the black carbon fiber hood. Or maybe it's for the 91+?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
SWEET :evilgrin:
I look forward to seeing the new rocket flying around the track! :hail:
BTW, can I have a ride? :naughty:
