Help fast!!!
Snow
Scranton, PA
I am buying an 1998 SHO and the owner says it cranks and starts but will not stay running. He said a "mechanic" friend of his said the cams might need welding. Couldn’t it be a air idle control valve?
SHO#7
Cincinnati
I would go with the owners recommendations. However, if it will not stay running... I would say it needs more than just welded. Sounds like it needs cams, valves, maybe even a piston since they continue to try and make it run. Offer him 500$ for it. And get ready to do your homework on www.v8sho.com
Good Luck
Sounds like it is too late. :(
Does it sound like a diesel engine running?
black93sho
Ohio
Is this the Black 98 SHO off ebay? If it is it looks like its in really good shape.
