headlights gawd they are so .... not bright?
Evil Sneak
Taunton, MAss
any remedies for these dim headlights? i heard rumors of a harness that i can use to run higher wattage bulbs? i got a set of dual beam CATZ fogs and they r brighter than my headlights.
can anybody shed some light on that. lol pardon my pun. heh
finally got my gauges in.. took em 12 days to send it. i find that annoying. now i gotta install em. the inverter better work or i am whippin out the sr8.~joke) lol i think i play too much Urban terror its getting to me.. :rolleyes:
First make sure the are aimed properly, most are too low. Then get some Sylvania SliverStars and a 100w headlight harness from a vendor such as Competition Limited
Westerly, RI
I'll second the Silverstars. I put them in our 97 SLO, and what a difference. Paul is that harness necessary, I didn't put one in ours. I was under the assumption that the stock harness was good enough?
Osiris
Grill Man
Oklahoma
I'll third the sliverstars. I put them in my SHO when I replaced the whole headlight assemblies back in June of last year. They will certainly make it easier to see, believe me.
I really do think that this car should have has some other type of lighting system, even a set of good driving lights, it realy lacks that front corner visibility.
The harness is not necessary. But the harness will make as big a difference as the new bulbs IMHO. The Gen 3 headlight wires are somewhere around 20ga.
Fast 3.4
New Jersey
How do I remove the front headlights? I removed the three gray bolts and tried to pull and push and pry. The things won't come out! :mad:
SHODWN
Mother Threasa
Spencer,Ma usa
you missed one way down behind the unit, just loosen this one and slide the unit out
Fast 3.4
New Jersey
Will I have to reset my fuel pump???? :confused:
<small>[ January 16, 2003, 08:19 PM: Message edited by: Fast 3.4 ]</small>
XLSuruaT
HB, CA USA
Fast 3.4:
You dont need to do that. You need to slip your hand down there, and pry the harness off the bulb. There is the connector kurt is talking about, and you unscrew that, then the bulb comes out.
There is a tall standing pinch bolt on the back side of the headlamps. Loosen this a few turns.
Fast 3.4
New Jersey
SE 2SHOSE,there is like no room to take the bulb out from behind the light, one of my mechs. here at the dealership told me the best way is to remove the whole headlight.
XLSuruaT
HB, CA USA
Which side are you talking about? If its the right side (standing in front facing the engine), you need to unclap some electric thing from the plastic surrounding and turn it upwards. That will give you enough room to squeaze your arm in through the otherside and slip the bulb out. It's a pain at first, but it can be mastered wink I used a flat head screwdriver to push the pins on the socket appart, then I pulled the socket off with my other hand. If its the left, then you gotta just squeaze your hand down there. Lemme know how it works out.
<small>[ January 18, 2003, 03:16 AM: Message edited by: SE 2 SHOSE ]</small>
Fast 3.4
New Jersey
You have a six right? I just looked at a DOHC six on my lot and my SHO seems to be a little bit tighter to get the bulbs than a six would be.
kaoticSHO
Thread Killer
sitting upon the Grimpon
PrplSHO:
Hey Prpl, I will be back up in the Hill Country this week. If you want to see how I handled the lack of front corner visibility maybe we could meet somewhere. I also recommend the Silverstars.
XLSuruaT
HB, CA USA
Fast 3.4:
Doh, mybad. I didn't think it would be that cramped up in the front, but anythign worse than a 6, then yank those assemblies out. You may have to stick your hand back there and pry the socket off because I dont think there is enough give in the wire take the assemblies out very far.
Fast 3.4
New Jersey
Its cool man, yeah as soon as we get a warm day here in Jersey I pull those lights out and change to my Xeons thumbs_u P.S. its like 16 degrees here now. BURRRR
