My 91 with 194,000 miles has gave me problems after the tune up.I have a bad idle from about400 to about 1,500 RPM.I also have fuel that bubbles out of the schrader valve and a loud whistle at about 2,500 RPM.I ran some codes.I hope you guys can put some part names with these codes.
18-check base timing and advance function (M)ignition signal erratic
41-system lean.system was lean for 15 seconds or longer (no HO2S switching)
85-2.3l T/C Automatic-3/4-4/3 shift solenoid CANP solenoid.(ALL 1989) 1.9 MFI-system corrected rich condition.
system running lean.Transmission SS1.circuit/solenoid problem.
