Has anyone tried this ebay hd headlight harness?
hawkeye18
Sorta cares
Norfolk, VA
It seems fine. Headlight relay harnesses are very simple creatures, and 10ga wire is fine for headlights. I don't understand why SUVlights.com or whatever wants $55 for a set; they're quit cheap to make yourself provided you have the knowledge and motivation...
SHO92
Upper Freehold, NJ
It was priced out a while back to make one yourself. When you added up the parts and time, the SUV harness was totally reasonable.
A pre-made harness takes just a few minutes to install, instead of cutting, soldering, and sourcing the supplies.
Bottom line, the harness is a great addition no matter if you make it or buy it.
NJSHO
Clean Your Shorts!
NJ
I made my own harness, and I also helped SHO92 install the SUV lights harness. I can honestly say that I wish I had just shelled out the 55 bucks (and Im a DIYer to the end.)
If you do get the ebay harness, and are going to use higher wattage bulbs, just make sure that the connectors to the bulb are hd connectors and not just stock replacement connectors.
whiteman_01
Well-Known Member
Hastings, MN
I have also been torn between making my own and buying a pre made harness. Mabey i will give this one a try just for kicks.
whiteman_01
Well-Known Member
Hastings, MN
My brother ordered one of these harnesses. It will be here at the beginning of next week, so we will see how good it really is.
