GTP Rear Control Arm/Spacer & Washer Info Needed
bigdaddy
Nashville
Installing a set of these arms on my 92.Does anyone have the ID and OD of the spacers? If i had the dimensions i could make a set on my metal lathe also the washers you buy from SHO Nut,i believe come in Ford parts bags,would anyone have a bag with the Ford part number on it? I have a good connection at the Ford dealer and i could buy these washers CHEAP!!! Thanks for you time. thumb
speedy91
West Des Moines, IA
No offense, but SHOnut's kit is not that expensive and it comes with everything you need. I know that he does not make a killing on these kits so I doubt you could make them much cheaper.
Eric
crystizel
