Gen 1 sho 3.0 motor blown, crank snapped apart, pics
chrism3784
West Palm Beach, Florida
Driving back from virginia to florida, 1200 mi each way, literally 10 miles from my house the crankshaft snaps apart, sounded like the motor exploded, oil pan broke apart. No idea what caused this. Had good oil, oil pressure seemed ok, no light. Freak thing maybe? Maybe has something to do with the underdrive pulley, since it doesn't have a dampener, vibrations slowly cracked it?P1040192 P1040193 P1040194 P1040195 P1040196 P1040197 P1040198 P1040199 P1040200 P1040193 P1040194 P1040195 P1040196 P1040197 P1040198 P1040199 P1040200
bummer! I bet that 'bang' got your attention...
itwonder
VA
Hope you can find a JY replacement without too much trouble. I'd ditch the aftermarket pulley.
SHOVNST
Blood type: SHO+
Niwot, CO
I have a hunch the aftermarket pulley is at minimum partially to blame.
zak
east of Hartford
Was or is this car supercharged or NA? Usually the underdrive crank pulley only takes out cranks on supercharged cars (yours might be the first NA victim - miles?)
sperold
Last to Know
With all the rods still attached to the crank journals, what took the bottom out of the pan?
Did the crank break in the center section of the block?
What does the top of the engine look like, are the pistons intact?
I have a limited imagination, so I cannot imagine what happened here. But here is one thought; what would happen if the firing order went out of phase and plugs fired long before the piston was near the top.
With the drive wheels demanding the crank location being at one place and the shutter wheel demanding power strokes that do not coincide, could that stress a crank to the point of breaking?
If this sounds crazy, I have to agree, but everything else seems even more crazy.
I would look at the shutter wheel and the crank sensor for a clue on that presumption.
Does not having a traditional crank pulley affect the shutter wheel in any way?
pjtoledo
'ol man in the SHO
toledo,ohio,usa
examine the crack surfaces. if there are any smooth areas the crack has been working for a while. if the entire crack surface is jagged it was most likely an instantaneous event.
why does the crank look a lot cleaner than the rest of the components?
pjtoledo
'ol man in the SHO
toledo,ohio,usa
not the first N/A crank breakage. there was one in Michigan 12-15 years ago.
tompumped
VT
I've been running a shosource soid pulley since Dec '10 and it's my daily driver that i'm not easy on by any means. I am leaning more towards the fact that it serves a purpose as designed. My experience isn't sufficient enough to make a determination.
IIRC the motor in the thread was rebuilt, but i'm probably getting it confused with another thread as I couldn't find it through a search of his username.
I'm not sure if it was these engines, but people have recommended against using machined cranks with undersize bearings, because it changes the fillet of radii of the crank. People in the past experienced breakage as a result.
313tiger
