Gasket identification
tompumped
VT
I just got a full oem gasket set in the mail today and the only thing it seems to lack is the oem oil cooler gasket.
The bag on the left has that one copper gasket with the strange ID where does it go? I know but I can't remember.
That stainless gasket in the bag on the right is throwing me off also? Where the **** does it go?
I never imagined a full gasket set would include fuel rail gaskets and timing cover gaskets. This is pretty amazing. I wish I had this when I was refreshening my spare engine.
20170707 1933161 20170707 1932591
It looks familiar but I can't place it. Is there a part number on the bag? Maybe that can be referenced for contents?
tompumped
VT
The tag says "Prepack #5". The only part number is on the outside of the cardboard box.
Irish Pride
Irish Inside
MusicCityUSA
The stainless gasket on the right is an EGR Valve gasket. The copper ring on the left might be the low oil level gasket/seal.
tompumped
VT
I didn't check the part number because I trusted the seller. I know the CA emission 3.0s came with egr so maybe that's the reason it's included? Hopefully I didn't purchase a 3.2 kit.
You just reminded me the oil level sensor gasket is missing also, they stated in the auction that some gaskets might be missing. So far there's two that I know of. I was also surprised to see that the front crank seal wasn't an NOK seal as was the camshafts and rear main. It's sealed in "prepack #3" so I know it's oem.
*edit*
I found the company that made the crank seal. It has dimensions right on it which is pretty unheard of plus their logo and some other marking.
http://www.arai-net.com/english/about/
zoomlater
Seattle, WA
The copper gasket looks like the one that goes under the fuel pressure regulator or the fuel pressure damper
