goalieman59
Learning Slowly
Just like the title states when I pull the handle in the car the door does not let go. I have to open the trunk and pull the release in the trunk, and then use a key to open the door. How can I fix that?
Got trunk fixed, have the part to fix gas tank but need time to put it on.My wife's car's trunk wouldn't open when the inside handle was pulled but worked just fine when the trunk button on the key fob was pushed. the solution was to take those two rubber bump stop thingies and unscrew them a little bit so they were sticking farther out. This puts upward pressure on the trunk and when you pull the lever, the trunk pops open. Voila!
As far as the gas door clip goes: Go to rockauto.com. Go to the part search tab, and type in 47201. It's like $2.70. Buy like 10.
