wow
time to datalog now. Let the fun begin.
Passenger side axle is the way to do it. Just remember the oil feed line is the last thing on removal and the FIRST thing on installation lol
you can even leave the stub shaft in place and just pull the outer half shaft so you don't have trany oil all over.Good stuff, I will remember that for my install.
you have to have somebody hold the rear turbo up in place and you have to bolt it in from the top. make sure to check the feed line oil screens for debris. now I can see why these motors need good oil changes.
Yes there is a guide. And no I did not drop the cradle. 2 and half days all by my self. Not bad job. Heat shields was my big down fall.Did you drop lower the cradle?
Pretty sure I remember @802SHO removed the passenger side axle and was able to tetris it out.
